I have done som testing for regenerate the problem and it seems to me it could be a network problem. When I'm loosing the network connection oracle does not close the sessions. When I'm logging on again, oracle / PL/SQL developer will start a new session. Even though I have not closed down the sql windows or closed down PL/SQL developer.
I'm currently working on a project where the network unfortunately is not stable all the time.
I'm attaching the debug log, thanks for helping!
PL/SQL Developer 7.1.2.1362
25/11/2007 16:01:44 Application started
25/11/2007 16:01:44 InitPreferences
25/11/2007 16:01:44 Load C:\Program Files\PLSQL Developer\Preferences\Default = 0
25/11/2007 16:01:44 PreferenceSet.Load C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
25/11/2007 16:01:44 PreferenceSet.Load OK
25/11/2007 16:01:44 Load C:\Documents and Settings\steinole.EU.000\Application Data\PLSQL Developer\Preferences\steinole = 0
25/11/2007 16:01:44 PreferenceSet.Load C:\Documents and Settings\steinole.EU.000\Application Data\PLSQL Developer\Preferences\steinole\default.ini
25/11/2007 16:01:44 PreferenceSet.Load C:\Documents and Settings\steinole.EU.000\Application Data\PLSQL Developer\Preferences\steinole\user.prefs
25/11/2007 16:01:44 InitPreferences end
25/11/2007 16:01:44 SortPreferenceSets
25/11/2007 16:01:44 - Default steinole
25/11/2007 16:01:44 - System Default
25/11/2007 16:01:44 LoadPreferences
25/11/2007 16:01:44 LoadPreferences searching for default
25/11/2007 16:01:44 C:\Documents and Settings\steinole.EU.000\Application Data\PLSQL Developer\Preferences\steinole\default.ini
25/11/2007 16:01:44 LoadPreferences NewPref := nil
25/11/2007 16:01:44 LoadPreferences Reading preferences
25/11/2007 16:01:44 LoadPreferences ReadPosition
25/11/2007 16:01:44 LoadPreferences ToolsBrowserItemClick(nil)
25/11/2007 16:01:44 LoadPreferences CreateBrowserFilters...
25/11/2007 16:01:44 LoadPreferences Files
25/11/2007 16:01:44 LoadPreferences Logon
25/11/2007 16:01:44 LoadPreferences Buttons
25/11/2007 16:01:44 LoadPreferences Printer
25/11/2007 16:01:44 LoadPreferences BrowserFolders
25/11/2007 16:01:44 LoadPreferences end
25/11/2007 16:01:44 FormCreate Logon.Execute
25/11/2007 16:01:48 TOracleSession PLSQLDevForm.Session Start Session.LogOn as eckernel_ectest@QG_TEST.QG.COM
25/11/2007 16:01:48 TOracleQuery BytesPerCharacterQuery Start Query.Execute
25/11/2007 16:01:48 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0.016
SQL = select lengthb(nchr(20000)), nchr(20) from dual
Duration = 0.015
25/11/2007 16:01:48 TOracleQuery Query Start Query.Execute
25/11/2007 16:01:48 TOracleQuery Query End (1 record processed)
Duration = 0
25/11/2007 16:01:48 TOracleSession PLSQLDevForm.Session End
Duration = 0.156
25/11/2007 16:01:48 LogonHistorySave start
25/11/2007 16:01:48 ChangeUserPref LogonHistory,
25/11/2007 16:01:48 ChangeUserPref DSA,
25/11/2007 16:01:48 ChangeUserPref end
25/11/2007 16:01:48 ChangeUserPref ColumnAssociations,
25/11/2007 16:01:48 ChangeUserPref ImportAssociations,
25/11/2007 16:01:49 ChangeUserPref BrowserFilters,
25/11/2007 16:01:49 ChangeUserPref end
25/11/2007 16:01:49 ChangeUserPref BrowserFolders,
25/11/2007 16:01:49 ChangeUserPref SessionQueries,
25/11/2007 16:01:49 ChangeUserPref ExternalTools,
25/11/2007 16:01:49 ChangeUserPref Documents,
25/11/2007 16:01:49 ChangeUserPref Reports,
25/11/2007 16:01:49 LogonHistorySave end
25/11/2007 16:01:49 FormCreate Session.Connected
25/11/2007 16:01:49 FormCreate Logon.Executed -1
25/11/2007 16:01:49 FormCreate TDBNames.Make
25/11/2007 16:01:49 FormCreate SessionChanged
25/11/2007 16:01:49 TOracleQuery Query Start Query.Execute
SQL = select * from v$version
25/11/2007 16:01:49 TOracleQuery Query End (5 records processed)
Duration = 0
25/11/2007 16:01:49 SessionChanged SetDBAViews
25/11/2007 16:01:49 TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
SQL = select object_name from sys.dba_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
25/11/2007 16:01:49 TOracleQuery PLSQLDevForm.DynamicQuery End
Duration = 0.016
SQL = select object_name from sys.all_objects where owner = 'SYS' and object_type = 'VIEW' and object_name like 'DBA%'
25/11/2007 16:01:49 TOracleQuery PLSQLDevForm.DynamicQuery End (2 records processed)
Duration = 0.016
25/11/2007 16:01:49 SessionChanged Authorizations.Load
25/11/2007 16:01:49 TOracleQuery $02CB18F0 Start Query.Execute
sys.plsqldev_authorization
25/11/2007 16:01:49 TOracleQuery $02CB18F0 End
Duration = 0
25/11/2007 16:01:49 SessionChanged EnableAuthorizedMenus
25/11/2007 16:01:49 TOracleSession $016FF1D0 Start Session.LogOn as eckernel_ectest@QG_TEST.QG.COM
25/11/2007 16:01:49 TOracleQuery Query End (1 record processed)
Duration = 0
25/11/2007 16:01:49 TOracleSession $016FF1D0 End
Duration = 0.063
25/11/2007 16:01:49 SetSessionAction starts: Main session
25/11/2007 16:01:49 TOracleQuery $02CB1A50 Start Query.Execute
from sys.user_objects o
25/11/2007 16:01:49 TOracleQuery $02CB1790 Start Query.Execute
SQL = select null from dual
25/11/2007 16:01:49 TOracleQuery $02CB1A50 End (100 records processed)
Duration = 0
25/11/2007 16:01:49 TOracleQuery $02CB1790 End (1 record processed)
Duration = 0
25/11/2007 16:01:49 TOracleQuery $02CB1A50 Start Query.Next for up to 100 records
:ACTION = Main session
Duration = 0
Duration = 0
25/11/2007 16:01:49 SetSessionAction ends
Duration = 0
25/11/2007 16:01:49 ExecuteConnectScript starts
25/11/2007 16:01:49 ExecuteConnectScript ends
Duration = 0.016
25/11/2007 16:01:49 TOracleQuery PLSQLDevForm.DynamicQuery End (1 record processed)
Duration = 0
Duration = 0
25/11/2007 16:01:49 SessionChanged LoadRecentObjects
25/11/2007 16:01:49 SessionChanged Notify children
Duration = 0
25/11/2007 16:01:49 SessionChanged Logoff secondary sessions
25/11/2007 16:01:49 SessionChanged SessionMode = smMulti
Duration = 0
25/11/2007 16:01:49 SessionChanged EnableChildFunctions
Duration = 0
Duration = 0
Duration = 0
25/11/2007 16:01:49 Toolbar.NavDisable
OracleHomeKey: SOFTWARE\ORACLE\KEY_OraClient10g_home1
OracleHomeDir: C:\Oracle\product\10.1.0\Client_1
Found: oci.dll
Using: C:\Oracle\product\10.1.0\Client_1\bin\oci.dll
Duration = 0
SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
25/11/2007 16:01:49 SortPreferenceSets
25/11/2007 16:01:49 - Default steinole
Duration = 0
25/11/2007 16:01:49 - System Default
Duration = 0
Duration = 0
25/11/2007 16:01:50 TOracleQuery $02CB1A50 Start Query.Next for up to 100 records
25/11/2007 16:01:50 TOracleQuery $02CB1A50 End (100 records processed)
Duration = 0
Duration = 0.015
Duration = 0
Duration = 0
25/11/2007 16:01:50 Toolbar.NavDisable
Duration = 0
25/11/2007 16:01:50 WMUpdatePopups starts
Duration = 0
25/11/2007 16:01:50 LoadDesktop starts
25/11/2007 16:01:50 LoadDesktop ends
Duration = 0
25/11/2007 16:01:50 WMUpdatePopups ends
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.032
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.016
25/11/2007 16:01:51 TOracleQuery $02CB1A50 Start Query.Next for up to 100 records
25/11/2007 16:01:51 TOracleQuery $02CB1A50 End (100 records processed)
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0
25/11/2007 16:01:51 TOracleQuery $02CB1A50 End (96 records processed)
Duration = 0
25/11/2007 16:01:51 TOracleQuery $02CB1A50 Start Query.Execute
from sys.all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
Duration = 0.171
Duration = 0
Duration = 0.016
Duration = 0
Duration = 0.016
Duration = 0.016
Duration = 0.015
Duration = 0.016
Duration = 0
Duration = 0
Duration = 0
Duration = 0
Duration = 0.015
25/11/2007 16:01:52 TOracleQuery $02CB1A50 End (67 records processed)
Duration = 0.094
25/11/2007 16:01:52 TOracleSession $016FF1D0 Start Session.LogOff
25/11/2007 16:01:52 TOracleSession $016FF1D0 End
Duration = 0
25/11/2007 16:01:54 Create TSQLForm Start
25/11/2007 16:01:54 Create TSQLForm Inherited
25/11/2007 16:01:54 TSQLForm.FormCreate Start
25/11/2007 16:01:54 SQLForm
25/11/2007 16:01:54 TSQLForm.FormCreate Finished
25/11/2007 16:01:54 Create TSQLForm SetupMainFont
25/11/2007 16:01:54 Create TSQLForm Activate
25/11/2007 16:01:54 Create TSQLForm Activate done
25/11/2007 16:01:54 Create TSQLForm UpdateWindowList
25/11/2007 16:01:54 Create TSQLForm Positioning
25/11/2007 16:01:54 Create TSQLForm Finished
25/11/2007 16:01:54 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:01:54 NavigationBookmarks: Backward=0, Forward=0
25/11/2007 16:01:59 SQLForm Initializing...
25/11/2007 16:01:59 SetConnected starts
25/11/2007 16:01:59 SetConnected: Connect starts
25/11/2007 16:01:59 TOracleSession $01701E70 Start Session.LogOn as eckernel_ectest@QG_TEST.QG.COM
25/11/2007 16:01:59 TOracleQuery Query Start Query.Execute
25/11/2007 16:01:59 TOracleQuery Query End (1 record processed)
Duration = 0
25/11/2007 16:01:59 TOracleSession $01701E70 End
Duration = 0.094
25/11/2007 16:01:59 SetConnected: (Dis)connect ends
25/11/2007 16:01:59 SetSessionAction starts: SQL Window - New
25/11/2007 16:01:59 TOracleQuery $02CB10B0 Start Query.Execute
25/11/2007 16:01:59 TOracleQuery $02CB10B0 End (1 record processed)
Duration = 0
25/11/2007 16:01:59 TOracleQuery BytesPerCharacterQuery Start Query.Execute
25/11/2007 16:01:59 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
:ACTION = SQL Window - New
Duration = 0.016
25/11/2007 16:01:59 SetSessionAction ends
25/11/2007 16:01:59 ExecuteConnectScript starts
25/11/2007 16:01:59 ExecuteConnectScript ends
Duration = 0.016
25/11/2007 16:01:59 EnableOutput starts
25/11/2007 16:01:59 TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
sys.dbms_output.disable;
else
sys.dbms_output.enable
size);
end if;
:ENABLE = 1
:SIZE = 10000
25/11/2007 16:01:59 TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
25/11/2007 16:01:59 EnableOutput done
25/11/2007 16:01:59 InitStatistics starts
25/11/2007 16:01:59 TStatistics.Init starts
25/11/2007 16:01:59 TStatistics.Init ends
25/11/2007 16:01:59 InitStatistics ends
25/11/2007 16:01:59 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:01:59 NavigationBookmarks: Backward=0, Forward=0
25/11/2007 16:01:59 SQLForm Executing...
25/11/2007 16:01:59 TSQLThread SQLThread.Execute
:ID = Null
Duration = 0
25/11/2007 16:01:59 TOracleQuery $02CB1370 Start Query.Execute
SQL = select * from dual
25/11/2007 16:02:00 TOracleQuery $02CB1370 End (1 record processed)
Duration = 0
25/11/2007 16:02:00 TOracleQuery SQLForm.TestQuery Start Query.Describe
SQL = SELECT * FROM dual
25/11/2007 16:02:00 TOracleQuery SQLForm.TestQuery End
Duration = 0
25/11/2007 16:02:00 TOracleQuery Query Start Query.Execute
:ID = Null
25/11/2007 16:02:00 TOracleQuery Query End
Duration = 0
25/11/2007 16:02:00 TSQLThread SQLThread Postmessage
25/11/2007 16:02:00 TSQLThread SQLThread Suspend
25/11/2007 16:02:00 TSQLForm.ThreadFinished
25/11/2007 16:02:00 TSQLForm.ThreadFinished: SQLThread.Suspended
25/11/2007 16:02:00 SQLForm 1 row selected in 0.125 seconds
25/11/2007 16:02:00 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:02:00 NavigationBookmarks: Backward=0, Forward=0
25/11/2007 16:02:00 TOracleQuery $02CB1210 Start Query.Execute
SQL = begin
:LINE = Null
:STATUS = Null
25/11/2007 16:02:00 TOracleQuery $02CB1210 End
Duration = 0
25/11/2007 16:02:01 Create TSQLForm Start
25/11/2007 16:02:01 Create TSQLForm Inherited
25/11/2007 16:02:01 TSQLForm.FormCreate Start
25/11/2007 16:02:01 SQLForm
25/11/2007 16:02:01 TSQLForm.FormCreate Finished
25/11/2007 16:02:02 AddNavigationBookmark starts
25/11/2007 16:02:02 AddNavigationBookmark GNV00001
25/11/2007 16:02:02 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:02:02 NavigationBookmarks: Backward=1, Forward=0
25/11/2007 16:02:02 AddNavigationBookmark ends
25/11/2007 16:02:02 Create TSQLForm SetupMainFont
25/11/2007 16:02:02 Create TSQLForm Activate
25/11/2007 16:02:02 Create TSQLForm Activate done
25/11/2007 16:02:02 Create TSQLForm UpdateWindowList
25/11/2007 16:02:02 Create TSQLForm Positioning
25/11/2007 16:02:02 Create TSQLForm Finished
25/11/2007 16:02:07 SQLForm Initializing...
25/11/2007 16:02:07 SetConnected starts
25/11/2007 16:02:07 SetConnected: Connect starts
25/11/2007 16:02:07 TOracleSession $034CB110 Start Session.LogOn as eckernel_ectest@QG_TEST.QG.COM
25/11/2007 16:02:07 TOracleQuery Query Start Query.Execute
25/11/2007 16:02:07 TOracleQuery Query End (1 record processed)
Duration = 0
25/11/2007 16:02:07 TOracleSession $034CB110 End
Duration = 0.078
25/11/2007 16:02:07 SetConnected: (Dis)connect ends
25/11/2007 16:02:07 SetSessionAction starts: SQL Window - New
25/11/2007 16:02:07 TOracleQuery $02CB09D0 Start Query.Execute
25/11/2007 16:02:07 TOracleQuery $02CB09D0 End (1 record processed)
Duration = 0
25/11/2007 16:02:07 TOracleQuery BytesPerCharacterQuery Start Query.Execute
25/11/2007 16:02:07 TOracleQuery BytesPerCharacterQuery End (1 record processed)
Duration = 0
Duration = 0
Duration = 0
25/11/2007 16:02:07 SetSessionAction ends
25/11/2007 16:02:07 ExecuteConnectScript starts
25/11/2007 16:02:07 ExecuteConnectScript ends
Duration = 0.016
25/11/2007 16:02:07 EnableOutput starts
25/11/2007 16:02:07 TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
SQL = begin
if :enable = 0 then
else
size);
end if;
:ENABLE = 1
:SIZE = 10000
25/11/2007 16:02:07 TOracleQuery PLSQLDevForm.EnableOutputQuery End
Duration = 0
25/11/2007 16:02:07 EnableOutput done
25/11/2007 16:02:07 InitStatistics starts
25/11/2007 16:02:07 TStatistics.Init starts
25/11/2007 16:02:07 TStatistics.Init ends
25/11/2007 16:02:07 InitStatistics ends
25/11/2007 16:02:07 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:02:07 NavigationBookmarks: Backward=1, Forward=0
25/11/2007 16:02:07 SQLForm Executing...
25/11/2007 16:02:07 TSQLThread SQLThread.Execute
:ID = Null
Duration = 0
25/11/2007 16:02:07 TOracleQuery $02CB0C90 Start Query.Execute
SQL = select sysdate from dual
25/11/2007 16:02:07 TOracleQuery $02CB0C90 End (1 record processed)
Duration = 0
25/11/2007 16:02:08 TOracleQuery SQLForm_1.TestQuery Start Query.Describe
25/11/2007 16:02:08 TOracleQuery SQLForm_1.TestQuery End
Duration = 0
25/11/2007 16:02:08 TOracleQuery Query Start Query.Execute
:ID = Null
25/11/2007 16:02:08 TOracleQuery Query End
Duration = 0
25/11/2007 16:02:08 TSQLThread SQLThread Postmessage
25/11/2007 16:02:08 TSQLThread SQLThread Suspend
25/11/2007 16:02:08 TSQLForm.ThreadFinished
25/11/2007 16:02:08 TSQLForm.ThreadFinished: SQLThread.Suspended
25/11/2007 16:02:08 SQLForm 1 row selected in 0.125 seconds
25/11/2007 16:02:08 NavigationBookmarks.EnableButtons(Rebuild)
25/11/2007 16:02:08 NavigationBookmarks: Backward=1, Forward=0
25/11/2007 16:02:08 TOracleQuery $02CB0B30 Start Query.Execute
SQL = begin
:LINE = Null
:STATUS = Null
25/11/2007 16:02:08 TOracleQuery $02CB0B30 End
Duration = 0.016
25/11/2007 16:02:29 TOracleQuery $02CB0B30 Start Query.Execute
SQL = select 'x' from dual
25/11/2007 16:02:48 TOracleQuery $02CB0B30 End
Result = ORA-03113: filslutt (EOF) p
