We are currently using DOA version 3.4.6.4 with an Intraweb (v5.0.61) ISAPI dll to implement an online application.
At first everything seems to work fine, at the (Intraweb) session timeout all the objects are freed and the oracle session (using OracleSession object) is discarded.
Then, when someone uses the application to update the database, causing a commit (or rollback on error), all subsequent oracle connections, made by any new online user, hang and are not discarded at the (Intraweb) session timeout. This also seems to keep the (Intraweb) session from closing properly and this also stays open indefinitely.
The only way to get rid of these connections seems to be unloading the ISAPI dll from ISS, which is not really an option in a production environment.
I don't know if this is related to the recent "unsafe destructors" post where the destructor does not completely remove the DOA connection.(?)
Please can you suggest anything, a workaround, to resolve this situation.
(We've tested with Oracle Cliente 8.1.6, 8.1.7 and 9.2.0 with the same results)
