Oracle Monitor 64 bit
giga
How can I monitor the queries made by 64 bit application. The monitor works only for 32 bit applications.
I have problem with the performance:
When I run 32 bit app the query for a report takes 1 second.
When I compile the code as 64 bit it takes 20 seconds and the mouse pointer changing many times to SQLWait that's why I need to monitor the queries to find out what happens.
The Oracle Monitor is only available as a 32 Bit version.
Such performance differences are usually caused by Oracle Client configuration differences. Can you verify if the 20 second delay is caused by TOracleSession.LogOn or TOracleSession.Connected := True?
For more detailed performance diagnostics you can use the global LogActivity event. Documentation with a complete example can be downloaded here.
