Patrick Wolf
the behaviour of the "Oracle Logon" dialog isn't very consistent. In the "Preferences" I have checked the "Store with password" checkbox.
1) The "Oracle Logon" dialog shows the last connection as default, but doesn't default the password. The user always has to enter the password or has to select the same connection from the context menu. => In that case the stored password is used.
2) Fixed users: I have defined several fixed users without a password. I would now assume that the password is stored the next time I use this user. But only if I select the connection from the history section the password is used, but it isn't used if I selected it from the fixed user section...
Regards
Patrick
PS: Using version 7.0.3.1123
Regards
Patrick
