Oracle 9i - Column Look up problem
Has anyone noticed a problem with using PL/SQL Developer with an Oracle 9i Database. We recently upgraded our test database to 9i, and now when I try to use the Tablename dot expansion or column names I get a huge long error message in an alert window telling me that the table or view doesn't exist. But I do the same thing an oracle 8i database and it works fine.
Any suggestions
I emailed the support staff at allroundautomations and they suggested to uncheck the "Use DBA views if available" option in the Tools -> Preferences [Option Tab].
That worked... Thanks Support Staff...
