Oracle 9i and DOA 3.3.2
zzato
Using oracle 9i via doa 3.3.2 give me this
error:
'A Query with lob requires OCI8 mode, but
OCI7 mode is used.
I try to do it via client 8i and client 9i
with same result.
I'm using d5 and on my connection object
related property is set to False.
Tnx x any answer.
Bye
zzato
You change OCI7 property in Session object...
Verify, if OCI7 property equal true, change for false and try only.OK
By.
It looks a bit like the thread "9i Client reverting to SQL*Net calls?" started on October 29 2001.
Also look at thread "DOA Compatibility with Oracle 9i" started on June 21 2001.
Greetings,
Frans
No need to apologize! Have sometimes done the same thing
Greetings,
Frans
