We recently upgraded from oracle 9i to oracle 10g release 10.2.0.3.0. I am having serious performance issues with pl/sql developer release 7.1.4.1389. The code assistant is performing very poorly. When looking at the session sql, I see this query everytime I call up the column list (when pressing .)
SELECT /*+rule*/ S.TABLE_OWNER, S.TABLE_NAME FROM ALL_SYNONYMS S WHERE S.SYNONYM_NAME = :B1 AND S.OWNER = 'PUBLIC' AND ROWNUM = 1
This query takes 6 seconds to run. However, when I remove the rule optimizer hint, it runs under 0.02 seconds. As of oracle 10g 10.2, the rule optimizer has been deprecated, so it should not be used anymore as performance are pretty bad.
I am now back to using version 7.0.3.1123 as this release doesn't seem to be affected by this issue. (it must not be using the optimizer hint).
Please advise.
Please advise.
