I have a customer that's presenting some problems after upgrade their database to Oracle 9i (9.0.1.0.0) for Linux.
The application was developed using Delphi4, QR 3.0.3, DOA 3.3.1 and Client ORA 8.0.5 on Win98 clients
The following steps are required to reproduce their error: they have a report that prints out some information based on database query; it's ok since only preview or print the report. But if you select preview function and then, using it's native print button the strange behaviour sets. After that, any query against database generate the EInvalidAccess exception leading to an ORA-03127 error.
We've already done the following tries to solve their problem:
1. change Oracle client to something closer to database version: 8.1.7 and 9.2.0.1. Both still present the same behaviour.
2. accordingly to other messages from this group we changed the DOA library to it's most recent version - 3.4.6; nothing happens
3. we've looked back in application to verify that's no multi-thread problem could be causing the troubles ... none of then was found. We've forcelly tried to set default values to don't use multi-thread but nothing happens too.
Well, if some of you have any other idea we'll be glad.
Thanks in advance
Alexandre
Thanks in advance
Alexandre
