ORA-24345 Not thrown by SQL Window
A strange phenomenon occured whilst executing the code below (in a SQL Window). The status bar told me that the code was executed, but looking at the dbms_output tab the statements after the call to sendmailjpkg package were not printed. Running the code in a SQL*Plus it appeared that an ORA-24345 occured. I cannot say if this occurs in de command window as well, as the cause of the error has been fixed, but I find it strange that such an Oracle exception is not thrown by the SQL Window. (I think this should be reproducable by turning of the java mailer, but I'm not sure).
DECLARE
  l_attachment_list  sendmailjpkg.attachments_list := sendmailjpkg.attachments_list();
  l_error_message    VARCHAR2(250);
  l_result           NUMBER;
  dbms_output.put_line('Begin');
  l_attachment_list.extend;
  l_attachment_list(1) := 'ORDERS_PROJECTS_NOT_CLOSED_19-AUG-2008.html';
  l_attachment_list(2) := 'ORDERS_PROJECTS_CLOSED_19-AUG-2008.html';
  l_attachment_list(3) := 'ORDERS_CANCELLED_19-AUG-2008.html';
  dbms_output.put_line('Send mail');
  l_result := SENDMAILJPKG.sendmail(smtpservername => 'mailhost'
                                   ,sender         => 'development@database.com'
                                   ,recipient      => 'recipient@gmail.com'
                                   ,subject        => 'DVL'
                                   ,body           => 'Test'
                                   ,errormessage   => l_error_message
                                   ,attachments    => l_attachment_list
  dbms_output.put_line('After send mail');
--  dbms_output.put_line('Result: '||l_result);
--  dbms_output.put_line('Error Message: '||l_error_message);
EXCEPTION
  WHEN OTHERS
  THEN
    dbms_output.put_line('Error: '||SQLCODE);
END;
