I'm using Version 12.0.7.1837 (64 bit).
When trying to use appendchildxml function I'm getting error:
The same sql works fine on PLSQL Developer Version 11.0.6.1776
So it seems related to newer/64-bit version of application.
[EDIT:] Hi Marco, thanks for swift response - I've sent you the information via priv message
Following is a very simple exaple that also causes the error:ORA-21500: internal error code, arguments: [%s], [%s], [%s], [%s], [%s], [%s], [%s], [%s]
SQL:
select appendchildxml(xmltype('<a><b><c>test1</c></b></a>'), '/a/b', xmlelement("c", null, 'test2')) from dual;
