ORA-12541 TNS No listener with pl/sql developer
malakay79
I have an oracle database 10.2.0.1.0 on windows 2003 server 64 bit.
And I have a client. In my client there is installed pl/sql developer.
When I try to connect to the dataaase with pl/sql developer I recivied this message:
but the lister is on.
I'm able to connect in my client with sqlplus: conn system/password@alias
and I'm able to use sql developer
So what can be the problem?
Maybe this an environment problem. Can you go to Help > Support Info, press the 'Copy all pages' button on this info screen, and paste this text into an e-mail reply?
In 5.1.6 you need to go to Help > About, press the Info (i) button, and press the 'Copy all pages' button on this info screen.
But if the 9i client works okay, then I assume that there is a tnsnames configuration issue with the other client.
