Greetings!
I'm having a strange problem. I get the "ORA-03114: not connected to ORACLE" while trying to compile a script that creates a procedure, from the Program Window.
I tried re-connecting, and executing the script again (right away)... The same error happens.
Running the script from SQL*Plus however presents no problems.
I was able to compile the same script yesterday, so I thought maybe the new code (I added some lines today) is causing the problem (the script is about 1400 lines long now), so I tried running the "old version" of the script... The same error
Help, anyone?
Thank you in advance.
Ivan C.
Help, anyone?
Ivan C.
