ORA-01461: can bind a LONG value only for insert into a LONG column
Hi guys,
I am getting
when I want to update a varchar(60) field in a table through doa (with a TOracleDataset).
There is no LONG field in the table. And I get this error not only on this table. I get this in every update on every table I use.
I tried running the sql which doa uses to update which I got from Oracle Monitor tool for doa, in sql plus. It works just fine.
The annoying is, the program works everywhere with no doubt.
The configurations:
Oracle 9.2.0.4.0
W2000 server
doa 3.4
and locale of server is Azeri(Latin) I don't know if this property has an impact.
