KanwarNasir
My application that I designed for Oracle 8i database generates the following error when it is run against Oracle 9i database. The error pops up when Post method is used to save an Inserted record using the TOracleDataset. Inserting a record through SQL statement (Execute method) works fine.
Are DOA components compatible with Ora9? If not, when can I expect DOA upgrade?
Thanks.
Thanks.
