ORA-01453 SET TRANSACTION must be first statement of transaction
From within a command window, I can do
> ALTER SESSION SET ISOLATION_LEVEL = SERIALIZABLE
without any problems. But, when the current isolation level is SERIALIZABLE, i cannot change it back to READ COMMITTED. I systematically get the above mentioned error message. In SQL*Plus, the problem does not occur.
Apparently the Command Window executes something else after executing a command. As a result, you can only use a SET TRANSACTION statement immediately after opening a new Command Window.
I will look into this, maybe this can be prevented.
