I make web application on a platform with next tools: Delphi 7 with Intraweb 10, DOA Ver. 4.1 for Delphi and Oracle11g. I am working a few days with DOA and I am very, very pleased. I have only one problem and this is "ORA-01036 on insert problem". So, I am trying to insert a record into the table "Cases" with a next structure:
desc Cases
Name Null Type
CASEID NOT NULL NUMBER
CASENBR NOT NULL VARCHAR2(6 CHAR)
EVIDNBR VARCHAR2(20 CHAR)
REGID NUMBER
CONTMETTYPEID NOT NULL NUMBER
CASETYPEID NOT NULL NUMBER
BUSPARTID NOT NULL NUMBER
OWNERID NUMBER
REPLID NUMBER
OUREPLID NUMBER
CASENAME NOT NULL VARCHAR2(70 CHAR)
CASEDESC CLOB
CREATEDATE NOT NULL TIMESTAMP(6)
FORWARDDATE TIMESTAMP(6)
LASTCHGDATE TIMESTAMP(6)
PRIORITY NOT NULL NUMBER
CASESTATUS NOT NULL NUMBER
ARCHIVED NOT NULL NUMBER
LOCKEDD NOT NULL NUMBER
LASTREPLIER NUMBER
OUANSWDATE TIMESTAMP(6)
OUANSWDESC CLOB
CLANSWDATE TIMESTAMP(6)
CLANSWDESC CLOB
I made storage procedure with next input parameters:
PROCEDURE INSERT_NEW_CASE (
I_CASENBR CASES.CASENBR%TYPE,
I_EVIDNBR CASES.EVIDNBR%TYPE,
I_REGID REGISTARS.REGID%TYPE,
I_CONTMETTYPEID CONTMETTYPES.CONTMETTYPEID%TYPE,
I_CASETYPEID CASETYPES.CASETYPEID%TYPE,
I_BUSPARTID BUSPARTNERS.BUSPARTID%TYPE,
I_CASENAME CASES.CASENAME%TYPE,
I_CASEDESC VARCHAR2,
I_PRIORITY CASES.PRIORITY%TYPE,
I_USERNAME USERS.USERNAME%TYPE)
and "insert" part of procedure body is:
SELECT CASE_GEN.NextVal INTO V_CaseID FROM Dual;
INSERT INTO Cases(CaseID,CaseNbr,EvidNbr,RegID,ContMetTypeID,CaseTypeID,
BusPartID,CaseName,CaseDesc,CreateDate,Priority, CaseStatus, Archived, Lockedd)
VALUES
(V_CaseID,I_CaseNbr,I_EvidNbr,I_RegID,I_ContMetTypeID,
I_CaseTypeID,I_BusPartID,I_CaseName,EMPTY_CLOB(),CURRENT_DATE,I_Priority, 0, 0, 0);
I use "spInsNewCase: TOracleQuery" component and within it I declared:
SQL =
INSERT_NEW_CASE
I_CASENBR, :I_EVIDNBR, :I_REGID,
:I_CONTMETTYPEID, :I_CASETYPEID,
:I_BUSPARTID, :I_CASENAME, :I_CASEDESC,
:I_PRIORITY, :I_USERNAME);
END;
and Variables =
spInsNewCase.SetVariable('I_CASENBR', ); -- String
spInsNewCase.SetVariable('I_EVIDNBR', ); -- String
spInsNewCase.SetVariable('I_REGID', ); -- Integer
spInsNewCase.SetVariable('I_CONTMETTYPEID', ); -- Integer
spInsNewCase.SetVariable('I_CASETYPEID', ); -- Integer
spInsNewCase.SetVariable('I_BUSPARTID', ); -- Integer
spInsNewCase.SetVariable('I_CASENAME', ); -- String
spInsNewCase.SetVariable('I_CASEDESC', ); -- String
spInsNewCase.SetVariable('I_PRIORITY', ); -- Integer
spInsNewCase.SetVariable('I_USERNAME', ); -- String
Delphi part of code is:
try
with UserSession, spInsNewCase do begin
SetVariable('I_CASENBR', UserSession.CurrCaseNbr);
SetVariable('I_EVIDNBR', EvidNbrEdit.Text);
SetVariable('I_REGID', UserSession.Paramm1);
SetVariable('I_CONTMETTYPEID', UserSession.Paramm2);
SetVariable('I_CASETYPEID', UserSession.Paramm3);
SetVariable('I_BUSPARTID', UserSession.Paramm4);
SetVariable('I_CASENAME', CaseNameEdit.Text);
SetVariable('I_CASEDESC', CaseDescMemo.Text);
SetVariable('I_PRIORITY', UserSession.Paramm5);
SetVariable('I_USERNAME', UserSession.UserName);
Execute;
end
except
on E:EOracleError ......
When I press "PostBtn" on Intraweb form I then get the following message:
"ORA-01036: illegal variable name/number"
and program is crashed, but RECORD IS INSERTED !!!
In Oracle SQL Developer everithing is OK, for example i enter next command:
INSERT_NEW_CASE
('A1B2C3', '1.11', 1, 4, 1, 11,
'aaaaaaaaa', 'bbbbbbb', 1, 'Rosko');
END;
and Oracle insert data into database.
So, where is the problem?
desc Cases
Name Null Type
REGID NUMBER
OWNERID NUMBER
REPLID NUMBER
OUREPLID NUMBER
CASEDESC CLOB
LASTREPLIER NUMBER
OUANSWDESC CLOB
CLANSWDESC CLOB
VALUES
SQL =
INSERT_NEW_CASE
END;
and Variables =
try
Execute;
end
except
INSERT_NEW_CASE
END;
