ORA-01008: not all variables bound ... in pl/sql developer 10.0.2.1697
Jeevan
I am using pl sql developer 10.0.2.1697.
and in sql window, I have a query which uses placeholders
select t.*, t.rowid from minf t
where t.p_mid = :MID;
How to use such queries in pl sql developer?
My colleagues are suggesting - switch Oracle SQL Developer, which prompts user for value to use for the placeholders.
which does not appeal to me (PL/SQL developer is THE tool for sql development).
thanks
Jeevan
Use a test window.
You could change your SQL window to a Test window with a right mouse click.
Tip: press the gray arrow in the black circle pointing down to fill in the variables
Thanks Roeland,
BTW, found another way,
In a SQL Window, itself, edit the query and use '&' instead of ':'
where t.p_mid = ∣
When the SQL is executed (F8 or Ctrl+F8) a window pops up, asking for values for place holder.
thanks
Jeevan
Then you are using substitution variables, and not bind variables. That's fine by me, but now you know it... :-)
