PL/SQL Developer 9.0.3
When I open or close windows (SQL, Command, etc) in maximized mode on high-resolution screen (1400x1050 and above) menu bar is blinking and operation goes slowly.
For not maximized window (but window size is about all screen) all is ok.
For low screen resolution (1366x768 and below) all is ok.
debug.txt with parameter option DebugSQL for maximized window
21.02.2013 20:32:14 NavigationBookmarks.EnableButtons(Rebuild)
21.02.2013 20:32:14 NavigationBookmarks: Backward=5, Forward=0
21.02.2013 20:32:17 Create TSQLForm Start
21.02.2013 20:32:17 Create TSQLForm Inherited
21.02.2013 20:32:17 TSQLForm.FormCreate Start
21.02.2013 20:32:17 Lock
21.02.2013 20:32:17 UnLock
21.02.2013 20:32:17 SQLForm
21.02.2013 20:32:17 TSQLForm.FormCreate Finished
21.02.2013 20:32:17 AddNavigationBookmark starts
21.02.2013 20:32:17 AddNavigationBookmark GNV00054
21.02.2013 20:32:17 NavigationBookmarks.EnableButtons(Rebuild)
21.02.2013 20:32:17 NavigationBookmarks: Backward=6, Forward=0
21.02.2013 20:32:17 AddNavigationBookmark ends
21.02.2013 20:32:17 Create TSQLForm SetupMainFont
21.02.2013 20:32:17 Create TSQLForm Activate
21.02.2013 20:32:17 UpdateChildList [timer]
21.02.2013 20:32:17 Create TSQLForm Activate done
21.02.2013 20:32:17 Create TSQLForm UpdateWindowList
21.02.2013 20:32:17 Create TSQLForm Positioning
21.02.2013 20:32:17 Create TSQLForm Finished
21.02.2013 20:32:17 ExecuteTemplateByName: Default\SQL Window
21.02.2013 20:32:17 ExecuteTemplate: C:\docs\distr\PLSQL Developer9\Template\Default\SQL Window.tpl
21.02.2013 20:32:17 Path: C:\docs\distr\PLSQL Developer9\Template\Default\SQL Window.tpl
21.02.2013 20:32:19 Lock
21.02.2013 20:32:19 UnLock
21.02.2013 20:32:19 NavigationBookmarks.EnableButtons(Rebuild)
21.02.2013 20:32:19 NavigationBookmarks: Backward=6, Forward=0
21.02.2013 20:32:19 DoUpdateChildList
21.02.2013 20:32:20 Lock
21.02.2013 20:32:20 UnLock
debug.txt with parameter option DebugSQL for not maximized window
21.02.2013 20:34:43 Create TSQLForm Start
21.02.2013 20:34:43 Create TSQLForm Inherited
21.02.2013 20:34:43 TSQLForm.FormCreate Start
21.02.2013 20:34:43 Lock
21.02.2013 20:34:43 UnLock
21.02.2013 20:34:43 SQLForm
21.02.2013 20:34:43 TSQLForm.FormCreate Finished
21.02.2013 20:34:43 AddNavigationBookmark starts
21.02.2013 20:34:43 AddNavigationBookmark GNV00062
21.02.2013 20:34:43 NavigationBookmarks.EnableButtons(Rebuild)
21.02.2013 20:34:43 NavigationBookmarks: Backward=3, Forward=0
21.02.2013 20:34:43 AddNavigationBookmark ends
21.02.2013 20:34:43 Create TSQLForm SetupMainFont
21.02.2013 20:34:43 Create TSQLForm Activate
21.02.2013 20:34:43 UpdateChildList [timer]
21.02.2013 20:34:43 Create TSQLForm Activate done
21.02.2013 20:34:43 Create TSQLForm UpdateWindowList
21.02.2013 20:34:43 Create TSQLForm Positioning
21.02.2013 20:34:43 Create TSQLForm Finished
21.02.2013 20:34:43 ExecuteTemplateByName: Default\SQL Window
21.02.2013 20:34:43 ExecuteTemplate: C:\docs\distr\PLSQL Developer9\Template\Default\SQL Window.tpl
21.02.2013 20:34:43 Path: C:\docs\distr\PLSQL Developer9\Template\Default\SQL Window.tpl
21.02.2013 20:34:43 DoUpdateChildList
