Keene Scouser
I am using an ODBC connection to connect to a AS400 tables, when I run a query in an SQL Window for the first time, everything works great. But....if I run the same query again in the same window I get the following error:
'ORA-28500: connection from ORACLE to a non-Oracle system returned this message: [Generic Connectivity Using ODBC]
if I open a new query window, and run the same query from there, it works fine again, or if I close and re-open PL/SQL Developer it will work again.
Any ideas what's happening, I use the same ODBC connection with other applications and have no problems with it.
Brian
Brian
