Hi All,
I have installed Oracle 10g on vista 64 bit. I have also installed PL/SQL developer (v 7.1.5) on the same machine. When i try to log into an oracle instance, it says that it could not load the oci.dll file - it shows me the path and it IS there, so I assuming its something to do with PL/SQL developer being 32bit and Oracle 10g 64 bit? if this is the case, how can I fix it? Is there a 64 bit version of PL/SQL developer? I have tried loading oracle 32 bit but it has problems as is not certified for vista 64 bit.
any ideas? Thanks
any ideas? Thanks
