Numbers with high scale are diplayed incorrectly
Hi, Marco!
numbers with high scale are diplayed incorrectly in "Version 12.0.7.1837 (32 bit)"
check this out
SQL:
SQL> select cast ('0,1' as number (*,37)) n from dual;
                                       N
                    0,100000000000000006
The 64 bit version works fine though.
This is a floating point rounding issue. If you go to Preferences > SQL Window you can enable the "Number fields to_char" option to display the number values with full Oracle precision in the SQL Window.
For the Command Window you would need to use the to_char() function.
