no regexp_replace in pl/sql developer 6.0.5
key_ray
i get: ORA-00904: invalid column name
after submitting select regexp_replace('ellen hildi smith','(.*) (.*) (.*)','\3, \1 \2') from dual;
whereas in an sqllus session, started on the same machine as pl/sqldev, connecting to the same 10g db:
i get:
REGEXP_REPLACE('EL
smith, ellen hildi
as expected!
Bug in pl/sql , some setting?
any help is appreciated
Regrds raymond
Works fine for me on 10g. It only fails with ORA-00904 when connected to 9.2. Are you sure you are connected to the same 10g database? You could run select * from v$version to be sure.
Just tried again.
All fine!!!!!!!!!
Indeed most likely did not use 10g the first time.
Now I think of it, we recently altered the tnsnames entires (due do different servers) and this may wel have caused the mixup!
Thanks for the response.
Sorry for the inconvenience
Raymond
