HI
I'm try to export objects current schema using command line command;
db.sql file:
the applicaiton is runing but i got message:
but if i run this string into command window it works fine.
plsqldev.exe noplugins UserID=user/pass@db Export Objects= IncludePrivs IncludeStorage IncludeOwner FilePerObject2 Filename="C:\db\db.sql"
db.sql file:
Export Objects= IncludePrivs IncludeStorage IncludeOwner FilePerObject2 Filename="C:\db\export.sql";
SQL>
Exporting Objects=
Could not execute, session was busy
Exporting Done.
