NLS_PARAMS/Regional setting problem
Robertas
it seems that PLSQL Developer is displaying data with oracle format but posting (after edit) with windows regional settings format. This example should reproduce this behavior
NLS PARAMS:
select * from nls_database_parameters
NLS_NUMERIC_CHARACTERS .,
select * from nls_instance_parameters
select * from nls_session_parameters
Windows regional settings
Decimal symbol: ,
Digit grouping symbol: .
PL/SQL Developer
numbers->Oracle format
--STEP1
create table test_tbl1(col1 number(15,3));
insert into test_tbl1(col1)values(5.3);
--STEP2
select t.*, t.rowid from test_tbl1 t
-- grid is showing: 5.300
--STEP3
-- edit value to 5.678 (eny value) , COMMIT
--STEP4
-- grid is showing: 5678.000
By default number values are displayed and edited in accordance with the Windows Regional Settings.
This can however be overruled by the SQL Window preference "Number fields to_char", which will apply Oracle NLS settings. Furthermore there is also an "NLS Setting" preference page where you can define the number format.
Thank you for your replay, but I get sorting problem in result grid when using "Number fields to_char"
for example ascending:
197781
1152538
1073774
any solutions?
PL/SQL Developer
Version 8.0.0.1494
Numbers are now fetched as text, so local sorting will also sort as text. Use an order by clause to get the sorted results from Oracle.
So there is no possibility to get numbers displayed as it is set in Oracle NLS settings and have values in result grid of their original type?
If you disable the "number fields to_char" option and set the number format preference (Tools > Preferences > NLS Options), you can get any formatting you like.
