"Next used Window" extreme slow in beta3
Set Key Configuration:
Window: Next used Window | Ctrl+Tab
Window: Previous used Window | Shift+Ctrl+Tab
When use Ctrl+Tab changing window is extreme slow in opposite to use Shift+Ctrl+Tab.
I'm not seeing any performance differences. In both cases it's instantaneous. As a test, can you assign different keys and try again?
I tried with Ctrl+ZIRKUMFLEX / Shift+Ctrl+ZIRKUMFLEX with the same effect.
After reinstall beta 3 I see only a slight delay using Ctrl+ZIRKUMFLEX or Shift+Ctrl+ZIRKUMFLEX. But I was surprised that Ctrl+Tab and Shift+Ctrl+Tab works as expected without settings in Key Configuration. And 2. surprise - this works without any notable delay.
Ok, so I should not configure Key for myself and use the defaults.
