Mutiple SQL in one SQL Window
M. Rokus
i have an SQL Window with 2 SQLs inside.
When i start it, 2 Results shows up. Now i wanne refresh only the Result of the second SQL.
Now i can mark the SQL and execute it. But is there another way?
Maybe something like, click into the result of the second SQL and press F3 ?!
Thanks for answering my quest!
Best regards,
Markus
You can via this way instead.
Select the grid page you want to refresh.
Click the button "Query by Example", and then click the button up.
Then you will see only this page data refresh.
