Multiple Instances in Double Click
Tarquino
PLSQL Dev always open a new instance when I double click a file associated to it.
Is there any preference to avoid this?
Alexandre Tarquino
You can drag the file to an open instance. Or you could drag the file to PLSD button in the task bar and then drag to that instance.
Marco,
My version is 7.1.5.1396
Gustavo,
It's so annoying to drag a file to a opened window. The behavior I expected is to reuse the current window to new files.
I saw that you are from S
I got used to dragging files. I do it for rtf files and other extensions, as I don't have admin privileges here, so program extensions and PLSD are not associated.
BTW, I'm from Salvador, I just live (sadly) in S
Perhaps you can go to Tools > Preferences > Files/Extensions, press the "Register Filetypes" button, press "OK" in the subsequent dialog, and try again?
Marco,
Didn't work.
But I have the solution and you can add this feature if you want in the near versions.
In the registry go to HKEY_CLASS_ROOT\PL/SQL Developer Key;
Navigate to Shell->Open and rename the key name ddeexec-disable to ddeexec;
Inside ddeexec navigate to Application and change the value DDLHOST to plsqldev
Done!
Now my PL/SQL Dev reuse the same window for all the file types associated to it.
Caution: it's better to backup the registry before the modifications.
Regards,
Alexandre Tarquino
Hello.
Does not work with 7.1.5.1398 here :(
REGEDIT4
[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\PL/SQL Developer\Shell\Open\ddeexec\Application]
@="PLSQLDEV"
"DDLHOST"="C:\Programme\PLSQL Developer\plsqldev.exe"
It'll be renamed back to 'ddeexec-disabled' everytime I close plsqldev.
Any ideas?
That is what I have too, and it works fine here. A first double-click opens a PL/SQL Developer instance. A second double-click opens the file in the same instance.
Can you check if the HKEY_CLASSES_ROOT\PL/SQL Developer section looks like this?
[HKEY_CLASSES_ROOT\PL/SQL Developer]
@="PL/SQL Developer file"
"FileTypes"="fnc..."
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\PL/SQL Developer\DefaultIcon]
@="U:\plsqldev\plsqldev.exe,1"
[HKEY_CLASSES_ROOT\PL/SQL Developer\Shell]
[HKEY_CLASSES_ROOT\PL/SQL Developer\Shell\Open]
[HKEY_CLASSES_ROOT\PL/SQL Developer\Shell\Open\Command]
@="\"U:\plsqldev\plsqldev.exe\" \"%1\""
[HKEY_CLASSES_ROOT\PL/SQL Developer\Shell\Open\ddeexec-disabled]
@="[Open(\"%1\")]"
[HKEY_CLASSES_ROOT\PL/SQL Developer\Shell\Open\ddeexec-disabled\Application]
@="PLSQLDEV"
Yes, it does :(
"FileTypes"="pck
sql
@="\"C:\Programme\PLSQL Developer\plsqldev.exe\" \"%1\""
@="[Open(\"%1\")]"
@="PLSQLDEV"
