Multiple Connections and Test window
Roeland
1) Make sure that "Multiple connections" is UNCHECKED!
2) Open a Test window and start debugging.
3) Go to session => Set Main Connection and choose another session...
This should not be possible!!! => "Set Main Connection" should be hidden or disabled when "Multiple connections" is UNCHECKED!
Roeland
PL/SQL Dev 9.0.0.1610
PS: The only workable workaround that I have found is to ALWAYS go to session => LOG OFF before changing connections.
I have the same problem when I use the LogOn-Button from toolbar.
Even I get an error that I can't change the connection while one or more windows are still executing, there are two connections shown in the connection window.
