moving away from toad questions
costa_basil
Hi:
I want to move away from using toad, however I have some questions:
- I want to use a dark background, I've been able to set a black background, but I can't change the color for identifiers from dark blue to something else. How can I do that?
- Can I export the data from a query to an excel spreadsheet (xls file)? Yes - this works I found it myself - the Copy to excel... option from the popup menu
- can pl/sql developer create a synchronize script between two schemas?
- does pl/sql dev support cursor columns. This query runs
SELECT CURSOR(SELECT SYSDATE FROM SYS.dual) FROM SYS.dual
but when I try to view the cursor I get an invalid cursor error
- can I view the results from a function that returns a cursor or from a procedure that returns output cursors?
That's it for now.
That should be in Tools -> Preferences -> Editor -> Syntax Highlighting
Yes, Tools -> Compare User Objects. Select a target session and Compare.
Seems to be a bug in the current version. I get the same error in 7.1.1.1339 but it works as expected in 7.0.3.1123.
Yes, use the test window and use a bind variable of type cursor. If you right-click on the procedure/function name and select test you should get a test window with correct bind variables automatically. And this works in current version.
Bo Pedersen
There is no option for identifiers, only keywords, comments, strings, numbers, symbols and custom.
The identifier colors is dark blue.
Where do I change it?
Thanks, and sorry, I didn't notice it, it was under my eyes all the time. I am usually accustomed to see all syntax highlighting settings in the same spot including the background.
