Hello!
MODEL clause seems to be not supported by Beautifier (v.7.0.1.1066).
For example see following query:
PL/SQL Beautifier formatted as:
Respectively, '[' and ']' signs are removed from original query, and formatted query will not compile. Additionally, it will be fine to see support of analytical functions in future Beautifier versions.
Thanks.
SELECT "Earning Record ID",
rv1 "Rate Record 1",
rv2 "Rate Record 2"
FROM (SELECT err.EARNING_RECORD_ID "Earning Record ID",
'Factor Subcategory = ' || LPAD(err.FACTOR_SUBCATEGORY_NAME, 28, ' ') ||
'; Rule Tag = ' || LPAD(err.RULE_NAME, 4, ' ') ||
'; Action = ' || LPAD(err.FACTOR_ACTION_NAME, 15, ' ') ||
'; Measurement Factor = ' || LPAD(err.MEASUREMENT_UNIT_NAME, 7, ' ') ||
'; Value = ' || err.VALUE "Rate Record"
FROM QA_ER_RULE_V err WHERE err.EARNING_RECORD_ID IN (1,10,11))
MODEL
RETURN UPDATED ROWS
PARTITION BY ("Earning Record ID")
DIMENSION BY(ROW_NUMBER() OVER (PARTITION BY "Earning Record ID" ORDER BY "Rate Record") rnk)
MEASURES("Rate Record" rt,
CAST('' AS VARCHAR2(1000)) rv1,
CAST('' AS VARCHAR2(1000)) rv2)
RULES (rv1[0] = rt[1],
rv2[0] = rt[2])
SELECT "Earning Record ID", rv1 "Rate Record 1", rv2 "Rate Record 2"
LPAD(err.FACTOR_SUBCATEGORY_NAME, 28, ' ') || '; Rule Tag = ' ||
LPAD(err.RULE_NAME, 4, ' ') || '; Action = ' ||
LPAD(err.MEASUREMENT_UNIT_NAME, 7, ' ') || '; Value = ' ||
WHERE err.EARNING_RECORD_ID IN (1, 10, 11)) MODEL RETURN UPDATED ROWS PARTITION BY("Earning Record ID") DIMENSION BY(ROW_NUMBER() OVER(PARTITION BY "Earning Record ID" ORDER BY "Rate Record") rnk) MEASURES("Rate Record" rt, CAST('' AS VARCHAR2(1000)) rv1, CAST('' AS VARCHAR2(1000)) rv2) RULES(rv1 0 = rt 1, rv2 0 = rt 2)
Thanks.
