Mixed Case and Export User Objects
mofleybk
Using Mixed Case (miXedCase) names in your Oracle objects causes a few fits for PL/SQL Developer. If you are working on a project converted from either MS Access or MS SQL Server, you most often get double quoted mixed case object names.
PL/SQL Developer cannot edit these objects...you have to manually add double quotes to your object names to edit data, etc.
I love PL/SQL developer and prefer it to Oracles SQL Developer. While they do have a beta version that handles mixed case quite well, I prefer the PL/SQL Dev environment. I especially love the schema export from "Export User Objects" in PL/SQL Dev as it does an awesome job of ordering the output. The built in right-click DBMS_Metadata-->DDL works great for mixed case, but doesn't allow for mass export in the proper order.
Any word on when a version of PL/SQL Developer will be available that support mixed case through and through?
Thanks.
Greetings,
I just downloaded and tested the new beta version 8 of PL/SQL Developer and it does not appear to solve the mixedCase issue.
Is there a menu/preferences setting that will allow PL/SQL Developer 8 to work with mixedCase table and field names?
