Frank Kintrup
I have two suggestions:
- It is not possible to assign a shortcut key to the refactoring actions, probably because they are not available from the main menu. This should be changed.
- The PL/SQL-Developer tends to leave a lot of spaces at the end of the lines. Either the Beautifier should have an option to remove those unwanted spaces or there should be an option to automatically strip them when saving a file.
Frank
Frank
