Koen Kamphuijs
My employer recently upgraded me to version 16 but I'm missing several options that I was pretty much attached to.
- I can't find the option to get multiple tabs in more than one row. I thought the setting User Interface/Options/use multi-row tabs was for that but that doesn't seem to do anything. I'm very much missing the overview when I have more tabs open than one line of tabs can hold.
- Is there a way to disable the lint? There was in previous versions. Due to some impairments, I need access through the keyboard very much, but with the lint, this is pretty cumbersome (yes I found the option to enable the alt key anyway - why would someone want to disable that???).
Also, when I alt-tab to another application, the shortcut letters stay visible in that application which is pretty annoying. I have to restart PL/SQL developer to get rid of that, and after some time it happens again.
Thanks in advance, Koen
