missing close icon [X] for sql Window
For most window types, no close icon (or minimize or restore) is displayed.
However, when I open the table editor, I see the icons for this window on the right at the level of the menu. Minimize and resize have no effect. Closing works there.
I'm using SDI with the settings "Don't show Tabs", "No Use multi-row tabs" and "Close button on tabs". Windows are usually maximized.
sql window without [X]
table editor
We cannot reproduce this. Can you let me know which window types display the [x], and which don't, so that we perhaps can find a common factor that is causing this?
yes I agree with fabrice. Here are some more pix to illustrate...
SDI with "Don't show Tabs" and Close button on tabs "Active" or "Active + Hover" or "None" or "All"
SDI with "Tabs on Top" and Close button on tabs "Active" or "Active + Hover"
SDI with "Tabs on Top" and Close button on tabs "All"
SDI with "Tabs on Top" and Close button on tabs "None"
This also a font color issue? On my screen these icons are white and the background is light grey. The icons are hardly visible...
