Misc Problems in Dev 6
TenGor
Hy,
i found some problems in the new PL/SQL Dev Ver. 6.0
1. in Preferences i can customize the Fonts.
in Browser: Verdana, 8 pt, bold
Main Font: Verdana, 8 pt
the Problem is, that my Browser is not in bold.
2. Toolbar:
when i move the "Button" "Seperator" with Mouse-Doubleclick or the ">" Button anything is alright. If i do this with drag&drop then entry "Seperator" disapear from the Available-List.
3. PlugIn Syntax-Highlighting
Which one is the correct for 6.0?
I have 1.1 but on the website there is 1.0.
The Problem is, that the CheckBox "Refresh on reconnect" can be set only on the 1st entry. If i set it for the second too, switch to the 1st and back the CeckBox is not set.
Everything else i see till now is absolutly wonderful! Doing a great job :D
Got an other "bug" (or feature?)
In Pl/Sql Dev i have the "Logon"-Button and there the LOV for the fixed SIDs.
In the Subfolder i see only 20 entries.
There should be about 50.
When i Startup Pl/Sql Dev and use the "..."-Button anything looks good.
