Until now, I am using SQL Developer, which is free tool from Oracle. The problem is that it is so buggy you wouldn't believe, so I would like to migrate to another free or payed tool.
I installed the trial version of PL/SQL developer, but I am little bit fighting with it. Here are my questions, notes...
1) First thing, new folder + new connection. Open the "Define connections" window, delete default folders and create a new one. When creating new folder, for what are there fields Username, Database, and Connect as?
2) New connection... Where can I fill SID and port? Database combo means what?
3) For the first look the design and icons are not much user friendly. For what somebody needs + and - buttons in Connections subwindow? That should mean add remove connection and not collapse expand. Icons are small not representing desired functionality. Renaming of folders only via connections dialogue...
