Memory Problem
mhajduk
Due to my last memory problem with copying large blob photo data using toracledataset i decided to due a test. My program opens a query and scrolls 300 records reading each record into memory. I then close the dataset and requery from the last record forward and read another 300 records. I can only do this for about 23,000 records before i get an out of memory error. This does not seem right, i should be able to do this for ever. Is the toraceldataset tool not releasing all prior used memory when you close the dataset and reopen.
All memory seems to be released. Memory Sleuth does not report any leaks either.
