Memory leak logon/logoff
weloby
I have a simple Delphi application with one OraSession component. In a timer I connect and immediately disconnect from a database. The timer ist executed every second. After a while a lot of memory is consumed as shown in the task manager.
I am using Delphi 6.
Timer code is like this:
procedure TForm1.Timer1Timer(Sender: TObject);
if not OracleSession1.Connected then
OracleSession1.LogOn;
if OracleSession1.Connected then
OracleSession1.LogOff;
Thanks for your help!
Regards,
Christian
