Max Count Plugins
Killservice
Hallo Marco,
is in PLD a max count of installed plugin's?
I use many of them and last I wanted to try "tao" Plugin and another one but allwys I becomea error in vcs plugin :-(
and if I delete 1 plugin (anyone) then all is good.
also is a max count in PLD or is VCS Plugin corrupted?
I use a user defined Plugins-Directory and now i have 2 plugins not on the list botton
PL/SQL Developer
Version 8.0.3.1510
Unlimited user license
Physical memory : 2.097.152 kB (2.097.152 available)
Paging file : 4.194.304 kB (4.194.304 available)
Virtual memory : 2.097.024 kB (1.602.772 available)
Plug-Ins
*Browser Extender version 2.0 by Joachim Rupik (PLSQL_DEV\plugins\be.dll)
*ColumnEdit v1.1 (..PLSQL_DEV\plugins\ColumnEdit.dll)
*Comment lines v1.4 (..PLSQL_DEV\plugins\commentline.dll)
*LBC Recall Named SQL (..PLSQL_DEV\plugins\LBCNamedSQL.dll)
*Lua Plug-In (..PLSQL_DEV\plugins\luaplug.dll)
*Information v1.0 (..PLSQL_DEV\plugins\selection_info.dll)
*TortoiseSVN add-in (..PLSQL_DEV\plugins\SVN_Plugin.dll)
*Templates v2.6 (..PLSQL_DEV\plugins\template.dll)
*User-defined Export 1.1 (..PLSQL_DEV\plugins\TextExport.dll)
*Version Control Interface 1.2 (..PLSQL_DEV\plugins\VCS.dll)
*Reconnect v1.0 (..PLSQL Developer\PlugIns\Reconnect.dll)
(* is Active)
We cannot reproduce the issue.
To obtain some more diagnostic information, can you modify the shortcut and add the Debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" Debug
Reproduce the problem and send me the vcsdebug.txt file that is generated in the PL/SQL Developer directory or in the %APPDATA%\PLSQL Developer directory (e.g. C:\Documents and Settings\\Application Data).
