Materialized View and Referenced By field
I am not sure if this is a bug or there is some setting in PL/SQL developer that I have not set correctly.
For tables,views etc when I click on the Referenced By field, it gives a list of dependent objects.
When I do the same for a Materialized View, it does not show any dependencies. Why is that?
Thank you,
The materialized view is not referenced directly. You will find this dependency under the underlying table.
