Match procedures with vcs
Ruudbern
Sometimes we check if there is a difference between the source in our vcs and the source in our devellopment oracle user.
Is there a easy way/tool to do this?
The compare plugin only compares the open window. I want to compare more than 1000 procedure, triggers etc. agains my filesystem. So the plugin would take to much time.
I now compare exports but its time consuming due to differences in trailing spaces, lines etc.
Any other tips/ suggestions?
Use the Export User Objects tool, use the "File per object" option, export the program units you want to compare, and run a script that performs a diff between the exported files and the VCS files.
