macro recording
At my PC, macro recording doesn't work at all. After starting macro recording the mouse and the keyboard freezes. They're locked until I press Ctrl+Alt+Del, call Taskmanager, close the Taskmanager and set the focus back to PLSQL-Developer. Then I do the commands I want to record, but when I stop macro recording there was no macro recorded. I've installed WinXP Prof (with actual patches), Office 2003 and newest plsql developer version. The workaround with reinstalling plsql developer has no effect.
We have had some more reports about this in 7.0, but have not yet been able to reproduce this.
I assume you are using version 7.0?
I've just discovered I have this same problem. As soon as I switch on macro recording PL/SQL Dev just hangs and nothing happens. I have to Ctrl, Alt, Del to get out of it. I have version 7.0.2.1076 on Windows 2000 Service Pack4.
To obtain some more diagnostic information, can you modify the shortcut and add the debug parameter? For example:
"C:\Program Files\PLSQL Developer\plsqldev.exe" debug
I had it working in version 6.0.5.926.
Then I have instaled the 7 trial version.
After that, Macro stop working.
I have uninstaled the version 7 and got back to the 6.0.5.926.
Then, the macros never worked again. I guess that something was left in registry or in the files that didn't dispared when I executed the uninstall.
Is there a solution? Thanks.
How exactly does it fail? Do you have the macro buttons on the toolbar? Does the macro indicator start to flash during recording? Does it stop afterwards? Does the macro replay?
I am facing the same problem. My keyboard freezes when I start macro recording and I have to go to Task Manager using ctrl+alt+delete and kill PL/SQL Developer. Also, I do not see any menu items under Macro menu.
Here's my setup:
PL/SQL Developer
Version 7.0.3.1123 (MBCS)
Windows XP version 6.0 (build 2600) SP 2
I have the same issues with the macros:
running from:
D:\Program Files\PLSQL Developer\PLSQLDev.exe
Any help would be appreciated
Here is how it does not work for me:
I opened PLSQL Developer, opened a new SQL Window, pressed F11 - pressed a couple of keys (did not work) - pressed ctrl+alt+delete - closed the task manager - pressed some more keys - pressed F11 again - pressed F12 - Nothing happened ! - repeated the same steps again - then closed the window and closed the program !
Here the debug messages:
PL/SQL Developer 7.0.3.1123 01.27313 - 10 user license
2/19/2007 6:03:53 AM Application started
2/19/2007 6:03:53 AM InitPreferences
2/19/2007 6:03:53 AM Load D:\Program Files\PLSQL Developer\Preferences\Default = 0
2/19/2007 6:03:53 AM PreferenceSet.Load D:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
2/19/2007 6:03:53 AM PreferenceSet.Load OK
2/19/2007 6:03:53 AM PreferenceSet.Load D:\Program Files\PLSQL Developer\Preferences\Default\temp.ini
2/19/2007 6:03:53 AM Load D:\Program Files\PLSQL Developer\Preferences\TBE2001 = 0
2/19/2007 6:03:53 AM PreferenceSet.Load D:\Program Files\PLSQL Developer\Preferences\TBE2001\default.ini
2/19/2007 6:03:53 AM PreferenceSet.Load D:\Program Files\PLSQL Developer\Preferences\TBE2001\user.prefs
2/19/2007 6:03:53 AM InitPreferences end
2/19/2007 6:03:53 AM SortPreferenceSets
2/19/2007 6:03:53 AM - Default TBE2001
2/19/2007 6:03:53 AM - System Default
2/19/2007 6:03:54 AM LoadPreferences
2/19/2007 6:03:54 AM LoadPreferences searching for default
2/19/2007 6:03:54 AM D:\Program Files\PLSQL Developer\Preferences\TBE2001\default.ini
2/19/2007 6:03:54 AM LoadPreferences end
2/19/2007 6:03:54 AM FormCreate Logon.Execute
2/19/2007 6:03:59 AM LogonHistorySave start
2/19/2007 6:03:59 AM ChangeUserPref LogonHistory,
2/19/2007 6:03:59 AM ChangeUserPref DSA,
2/19/2007 6:03:59 AM ChangeUserPref end
2/19/2007 6:03:59 AM ChangeUserPref ColumnAssociations,
2/19/2007 6:04:00 AM ChangeUserPref end
2/19/2007 6:04:00 AM ChangeUserPref ImportAssociations,
2/19/2007 6:04:00 AM ChangeUserPref BrowserFilters,
2/19/2007 6:04:00 AM ChangeUserPref BrowserFolders,
2/19/2007 6:04:00 AM ChangeUserPref SessionQueries,
2/19/2007 6:04:00 AM ChangeUserPref ExternalTools,
2/19/2007 6:04:00 AM ChangeUserPref Documents,
2/19/2007 6:04:00 AM ChangeUserPref Reports,
2/19/2007 6:04:00 AM LogonHistorySave end
2/19/2007 6:04:00 AM FormCreate Session.Connected
2/19/2007 6:04:00 AM FormCreate Logon.Executed -1
2/19/2007 6:04:00 AM FormCreate TDBNames.Make
2/19/2007 6:04:00 AM FormCreate SessionChanged
2/19/2007 6:04:00 AM SessionChanged SetDBAViews
2/19/2007 6:04:00 AM SessionChanged Authorizations.Load
2/19/2007 6:04:00 AM SessionChanged EnableAuthorizedMenus
2/19/2007 6:04:00 AM SetSessionAction starts: Main session
2/19/2007 6:04:00 AM SetSessionAction ends
2/19/2007 6:04:00 AM ExecuteConnectScript starts
2/19/2007 6:04:00 AM ExecuteConnectScript ends
2/19/2007 6:04:00 AM SessionChanged LoadRecentObjects
2/19/2007 6:04:00 AM SessionChanged Notify children
2/19/2007 6:04:00 AM SessionChanged Logoff secondary sessions
2/19/2007 6:04:00 AM SessionChanged SessionMode = smMulti
2/19/2007 6:04:00 AM SessionChanged EnableChildFunctions
2/19/2007 6:04:00 AM Toolbar.NavDisable
OracleHomeKey: SOFTWARE\ORACLE\HOME0
OracleHomeDir: C:\oracle\ora92
Found: oci.dll
Using: C:\oracle\ora92\bin\oci.dll
2/19/2007 6:04:00 AM SortPreferenceSets
2/19/2007 6:04:00 AM - Default TBE2001
2/19/2007 6:04:00 AM - System Default
2/19/2007 6:04:01 AM Toolbar.NavDisable
2/19/2007 6:04:01 AM WMUpdatePopups starts
2/19/2007 6:04:01 AM GetCrashList: 327954.cfg
2/19/2007 6:04:01 AM LoadDesktop starts
2/19/2007 6:04:01 AM LoadDesktop ends
2/19/2007 6:04:01 AM WMUpdatePopups ends
2/19/2007 6:04:05 AM Create TSQLForm
2/19/2007 6:04:05 AM SQLForm
2/19/2007 6:04:05 AM NavigationBookmarks.EnableButtons(Rebuild)
2/19/2007 6:04:05 AM NavigationBookmarks: Backward=0, Forward=0
2/19/2007 6:04:08 AM NavigationBookmarks.EnableButtons(Rebuild)
2/19/2007 6:04:08 AM NavigationBookmarks: Backward=0, Forward=0
2/19/2007 6:04:18 AM NavigationBookmarks.EnableButtons(Rebuild)
2/19/2007 6:04:18 AM NavigationBookmarks: Backward=0, Forward=0
2/19/2007 6:04:21 AM NavigationBookmarks.EnableButtons(Rebuild)
2/19/2007 6:04:21 AM NavigationBookmarks: Backward=0, Forward=0
2/19/2007 6:04:30 AM NavigationBookmarks.EnableButtons(Rebuild)
2/19/2007 6:04:30 AM NavigationBookmarks: Backward=0, Forward=0
2/19/2007 6:04:43 AM MainForm Closing
2/19/2007 6:04:43 AM ChangeUserPref , PlanViewType
2/19/2007 6:04:43 AM ChangeUserPref end
2/19/2007 6:04:43 AM ChangeUserPref Logon, Username
2/19/2007 6:04:43 AM ChangeUserPref Logon, Database
2/19/2007 6:04:43 AM ChangeUserPref Logon, ConnectAs
2/19/2007 6:04:43 AM ChangeUserPref , LastNewsRead
2/19/2007 6:04:43 AM ChangeUserPref , LastNewsItem
2/19/2007 6:04:43 AM ChangeUserPref , LastUpdateItem
2/19/2007 6:04:43 AM MainForm Closed
2/19/2007 6:04:43 AM Destroying TSQLForm
2/19/2007 6:04:43 AM Destroying - EnableChildFunctions
2/19/2007 6:04:43 AM Destroying - Session
2/19/2007 6:04:43 AM Destroying - Debugger
2/19/2007 6:04:43 AM Destroying - Free stuff
2/19/2007 6:04:43 AM Destroying - UpdateChildList
2/19/2007 6:04:43 AM Destroyed TSQLForm
2/19/2007 6:04:43 AM ChangeUserPref LogonHistory,
2/19/2007 6:04:43 AM ChangeUserPref DSA,
2/19/2007 6:04:43 AM ChangeUserPref ColumnAssociations,
2/19/2007 6:04:43 AM ChangeUserPref ImportAssociations,
2/19/2007 6:04:43 AM ChangeUserPref BrowserFilters,
2/19/2007 6:04:43 AM ChangeUserPref BrowserFolders,
2/19/2007 6:04:43 AM ChangeUserPref SessionQueries,
2/19/2007 6:04:43 AM ChangeUserPref ExternalTools,
2/19/2007 6:04:43 AM ChangeUserPref Documents,
2/19/2007 6:04:43 AM ChangeUserPref Reports,
2/19/2007 6:04:43 AM MainForm Destroying
2/19/2007 6:04:43 AM MainForm Destroyed
2/19/2007 6:04:43 AM Finalization HTMLUnit
2/19/2007 6:04:43 AM Finalization HTMLUnit done
2/19/2007 6:04:43 AM Finalization PLSCommon
2/19/2007 6:04:43 AM Finalization PLSCommon done
2/19/2007 6:04:43 AM Finalization DBObjectUnit
2/19/2007 6:04:43 AM Finalization DBObjectUnit done
2/19/2007 6:04:43 AM Finalization PlanUnit
2/19/2007 6:04:43 AM Finalization PlanUnit done
2/19/2007 6:04:43 AM Finalization DBNamesUnit
2/19/2007 6:04:43 AM Finalization DBNamesUnit done
2/19/2007 6:04:44 AM Finalization MacroUnit
2/19/2007 6:04:44 AM Finalization MacroUnit done
2/19/2007 6:04:44 AM Finalization HTMLUnit
2/19/2007 6:04:44 AM Finalization HTMLUnit done
2/19/2007 6:04:44 AM Finalization TotalRecallUnit
2/19/2007 6:04:44 AM Finalization TotalRecallUnit done
2/19/2007 6:04:44 AM Finalization RepUnit
2/19/2007 6:04:44 AM Finalization RepUnit done
2/19/2007 6:04:44 AM Finalization ReportCommon
2/19/2007 6:04:44 AM Finalization ReportCommon done
2/19/2007 6:04:44 AM Finalization RowExportUnit
2/19/2007 6:04:44 AM Finalization RowExportUnit done
2/19/2007 6:04:44 AM Finalization StatUnit
2/19/2007 6:04:44 AM Finalization StatUnit done
Thanks TBE2001
I've had the same issue, but haven't been able to track down a pattern where I could report useful info for you to replicate. It hasn't happened in about 4 week now, though. Keeping my fingers crossed that luck stays with me...
