Logon Connection on Workset
matejj
When I open PL/SQL Dev I get "Oracle Logon" list with connections. Then PL/SQL Dev opens Workset I use. It doesn't matter which connection I choose Workset always opens with last connection used. I suggest to skip "Oracle Logon" when PLSQL Dev opens Worset or to change connection of workset to connection form "Oracle Logon" list.
We'll see if we can enhance this.
As a workaround you can specify the NoLogon command-line parameter. For example:
"C:\Program Files\PLSQL Developer 15\ Beta\plsqldev.exe" NoLogon
