Little questions about Export data function
I often use the export data into a sql file of a table using a query because it generating the insert lines. Then I replay this script in another schema that have the same table to import data from source.
I would like to make a package or a function that will wrote in a sql file the same thing that your export data function.
There is my questions :
- How do you make the script ? Are you using the "exp.exe" function of oracle to export them with "insert/delete.."
I tried to make a macro when exporting data but it seem it doing nothing... Can I use macro to make the result of my first question ?
Hope I will have some answers :)
best regards,
MadoshiNatsu
