large query, Initializing problem
derik82
Hi Everyone,
I know there was a thread on this issue, but I cant find the solution in it.
I use PL/SQL Developer
Version 10.0.5.1710
01.89618 - 10 user license
Windows 8 (64-bit) 6.2 Build 9200
when I want to run large query, the "Initializing" take very long.
I want to run now a simple set of insert statement approximately 1000 inserts, the initialization takes endless time. Even at the end the pl/sql developer freezez.
Please can you help me how to fix this,
Best Regards,
Derik82
If you are doing this in the SQL Window it is best to place all the insert statements in a begin/end block:
  insert ...;
  insert ...;
Hi, thank you.
I just wondering how is it possible, that such a tool like pl/sql developer, can't run 100 insert statement without problem. What is it initializing? Will be there a fix?
regards,
szilard
The SQL Window is an interactive tool to run a limited number of SQL statements and manipulate the results. It is not designed to run massive batch scripts. For this purpose you should preferably use the Command Window.
