A andyh Member² Feb 25, 2010 #1 The LDE is not appearing when I try to view a BLOB in a table using 8.0.2.1505 i.e. by clicking the '...' button associated with the blob item. The same BLOB can be viewed using 8.0.1.1502.
Marco Kalter Administrator Staff member Feb 26, 2010 #1 This works fine for me, and we have not yet had any similar 8.0.2 problem reports. Can you check what happens if your hold down the Ctrl key when you click on the [...] button?
A andyh Member² Feb 26, 2010 #1 Ah... Acrobat had updated itself and was no longer the version pointed to by the 'external' PDF reference. Sorry for the inconvenience, but thanks for your help.
