Hi Marco,
Thanks for the quick response.
I constructed a small program in Delphi 6 to try and duplicate this problem as follows:
I'm using a table with three fields each of which is a NUMBER(10) and all of which are part of the Primary Key.
I created a new Project, dropped a TOracleSession and a TOracleQuery object on the form with a button to use to test. I set the connection information at design time. The OnClick of the button is as follows:
procedure TForm1.Button1Click(Sender: TObject);
var
V_ISSUEID: Variant;
V_ALIASID: Variant;
V_INCLUDEDID: Variant;
i: integer;
V_ISSUEID := VarArrayCreate([1,70000], varVariant);
V_ALIASID := VarArrayCreate([1,70000], varVariant);
V_INCLUDEDID := VarArrayCreate([1,70000], varVariant);
for i := 1 to 70000 do begin
V_ISSUEID
:= 66666;
V_ALIASID := i;
V_INCLUDEDID := i;
OracleSession1.Connected := True;
with OracleQuery1 do begin
DeclareVariable('ISSUEID', otInteger);
DeclareVariable('ALIASID', otInteger);
DeclareVariable('INCLUDEDID', otInteger);
SQL.Add('INSERT INTO ALIASES (ISSUEID, ALIASID, INCLUDEDID) ' +
'VALUES
ISSUEID, :ALIASID, :INCLUDEDID)');
SetVariable('ISSUEID', V_ISSUEID);
SetVariable('ALIASID', V_ALIASID);
SetVariable('INCLUDEDID', V_INCLUDEDID);
executeQueryIncrementally(OracleQuery1, 1000, 70000);
OracleSession1.Commit;
The executeQueryIncrementally function is as follows:
procedure executeQueryIncrementally(q: TOracleQuery; incSize, numRecords: integer);
var arrayPos, numArray: integer;
arrayPos := 0;
while arrayPos < numRecords do begin
numArray := numRecords - arrayPos;
if (numArray > incSize) then begin
q.ExecuteArray(arrayPos, incSize);
Inc(arrayPos, incSize);
end
else begin
q.ExecuteArray(arrayPos, numArray);
When the 65001-66000 ExecuteArray is executed I get a key violation. Given that every value in the IssueID variant is the same and every value in the AliasID and IncludedID are unique within an array location, this should have worked, yes?
I'm I doing something wrong with Array DML that isn't supported? Any suggestions would be appreciated.
Jeff Watson
