Keyboard navigation in insert statements is slow
Claus Pedersen
I have the following statements in an editor:
SQL:
insert into employees (EMPLOYEE_ID, FIRST_NAME, LAST_NAME, EMAIL, PHONE_NUMBER, HIRE_DATE, JOB_ID, SALARY, COMMISSION_PCT, MANAGER_ID, DEPARTMENT_ID)
values (100, 'Steven', 'King', 'SKING', '515.123.4567', to_date('17-06-2003', 'dd-mm-yyyy'), 'AD_PRES', 24000.00, null, null, 90);
values (101, 'Neena', 'Kochhar', 'NKOCHHAR', '515.123.4568', to_date('21-09-2005', 'dd-mm-yyyy'), 'AD_VP', 17000.00, null, 100, 90);
values (102, 'Lex', 'De Haan', 'LDEHAAN', '515.123.4569', to_date('13-01-2001', 'dd-mm-yyyy'), 'AD_VP', 17000.00, null, 100, 90);
values (103, 'Alexander', 'Hunold', 'AHUNOLD', '590.423.4567', to_date('03-01-2006', 'dd-mm-yyyy'), 'IT_PROG', 9000.00, null, 102, 60);
values (104, 'Bruce', 'Ernst', 'BERNST', '590.423.4568', to_date('21-05-2007', 'dd-mm-yyyy'), 'IT_PROG', 6000.00, null, 103, 60);
values (105, 'David', 'Austin', 'DAUSTIN', '590.423.4569', to_date('25-06-2005', 'dd-mm-yyyy'), 'IT_PROG', 4800.00, null, 103, 60);
values (106, 'Valli', 'Pataballa', 'VPATABAL', '590.423.4560', to_date('05-02-2006', 'dd-mm-yyyy'), 'IT_PROG', 4800.00, null, 103, 60);
values (107, 'Diana', 'Lorentz', 'DLORENTZ', '590.423.5567', to_date('07-02-2007', 'dd-mm-yyyy'), 'IT_PROG', 4200.00, null, 103, 60);
values (108, 'Nancy', 'Greenberg', 'NGREENBE', '515.124.4569', to_date('17-08-2002', 'dd-mm-yyyy'), 'FI_MGR', 12008.00, null, 101, 100);
values (109, 'Daniel', 'Faviet', 'DFAVIET', '515.124.4169', to_date('16-08-2002', 'dd-mm-yyyy'), 'FI_ACCOUNT', 9000.00, null, 108, 100);
I place the cursor on the first line and hold the right arrow key down to navigate. When the cursor hits the first word EMPLOYEE_ID and marks the corresponding value 100, the speed of the cursor movements slows considerably down. When you copy the sql lines a couple of times, so the editor contains e.g. 50 lines, the navigation speed using the keyboard becomes (exponentially?) slower.
In large files with e.g. 1000 lines, it can get almost impossible to use the keyboard to navigate inside sql when you have a lot of e.g. insert statements.
Please improve this.
I cannot reproduce this. I copied the text until I have 10,000 lines, but there are still no delays. Can you let me know which window type you are using?
It is in an SQL window, but it is the same in e.g. a command window.
I have sent a screen recording video to support, to demonstrate the situation.
Any updates?
Also navigating in SQL window is slow when PLD begins to mark code, e.g. table names or columns in a moderately large view (join on a couple of tables, approx. 50 lines of code).
This has been improved in version 13.0.4. Perhaps you can verify? We sent you a test version, but it seems you did not receive it?
