I had 7.1.1 installed and configured the keys to suit myself. This worked fine until a couple of days ago when I did a lot of configuring (changing folder colours in the browser, customizing the toolbar etc.) and then the key configurations stopped working. After searching the forum a bit, I decided to install the latest version 7.1.5 but it has not solved the key configuration problem.
I have configured Edit-Selection-Lowercase to Ctrl/L but pressing Ctrl/L brings up the Find box (or finds the next occurrence if there is already text to be found - this is default behaviour for Ctrl/L).
I have 3 Preference files and I have configured all of them the same way. Regardless of the preference file I choose, the problem remains.
Here is the listing from the Help/Support Info option:
PL/SQL Developer
Version 7.1.5.1398
02.56666 - Unlimited user license
Windows XP Professional 5.1 Build 2600 (Service Pack 3)
Physical memory : 1,046,596 kB (358,996 available)
Paging file : 2,518,940 kB (1,952,660 available)
Virtual memory : 2,097,024 kB (1,964,560 available)
Parameters
C:\Program Files\PLSQL Developer\PlSqlDev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
C:\Program Files\PLSQL Developer\Preferences\Default\Default.ini
C:\Program Files\PLSQL Developer\Preferences\crosbie_b\default.ini
C:\Program Files\PLSQL Developer\Preferences\crosbie_b\GIOS.ini
Plug-Ins
Aliases
(ADDRESS
(CONNECT_DATA
(DESCRIPTION
(PROTOCOL
(SID
admin.world
admin_bck.world
admin_dr.world
pccsp.world
tstmaina.world
Homes
DEFAULT_HOME (C:\orant)
DEFAULT_HOME1 (C:\ora8i)
Oracle_Developer10G (c:\Oracle_Developer10G)
Oracle6i (C:\Oracle6i)
DLLs
C:\ora8i\bin\oci.dll
TNS File
C:\ora8i\Network\Admin\tnsnames.ora
Using
Home: DEFAULT_HOME1
DLL: C:\ora8i\bin\oci.dll
OCI: Version 8.1
Oracle Database 10g Enterprise Edition Release 10.2.0.3.0
Character Sets
Character size: 3 byte(s)
CharSetID: 871
NCharSetID: 2000
Unicode Support: True
NLS_LANG: AMERICAN_AMERICA.WE8ISO8859P1
NLS_CHARACTERSET: UTF8
Here are the contents of my main preference file:
ID=PL/SQL Developer Preference File
[General]
Name=Default crosbie_b
Enabled=True
Order=0
Rules=
[Preferences]
OpenTransaction=2
CheckConnection=True
SelectedHome=Oracle_Developer10G
OCIFile=
UseDBAViews=True
PrefAutomaticStatistics=True
SelectedStatNames=
SpcExt=pks
BdyExt=pkb
PrgOthExt=spc,bdy,ops,opb
SqlOthExt=opb,ops,sqb,sqh
BackupFiles=0
BackupRelPath=Backup
BackupAbsPath=
AutoSelectSQL=True
ShowSQLWindowGutter=True
QueryResultStyle=2
QueryResultCount=100
SavePFInfo=True
PFInfoLocation=0
PFInfoRelPath=
PFInfoAbsPath=
AutoSaveDesktop=True
MultiRowTabs=True
CompleteFilePath=True
BrowserShowDatatypes=True
KeywordsEnabled=True
KeywordsBold=True
KeywordsItalic=False
KeywordsColor=255
KeywordsBkg=-16777211
CommentEnabled=True
CommentBold=False
CommentItalic=True
CommentColor=16711680
CommentBkg=-16777211
StringsEnabled=True
StringsBold=True
StringsItalic=False
StringsColor=6723891
StringsBkg=-16777211
NumbersEnabled=True
NumbersBold=True
NumbersItalic=False
NumbersColor=39423
NumbersBkg=-16777211
SymbolsEnabled=True
SymbolsBold=True
SymbolsItalic=False
SymbolsColor=8388608
SymbolsBkg=-16777211
CustomEnabled=True
CustomBold=True
CustomItalic=False
CustomColor=8388736
CustomBkg=-16777211
KeywordsCase=1
DisplayLineNrs=True
LineNrsInterval=0
LineNrsFont=Courier New
LineNrsFontSize=9
HighLightLine=True
BeautifierRulesFilename=M:\PLSQL Developer\BJC.br
UserDateFormat=DD-MMM-YYYY
DateFormatID=0
[ToolButtons]
FileLogonBtn
ButtonSeparator
UndoButton
RedoButton
ButtonSeparator
IndentBtn
UnIndentBtn
CommentBtn
UnCommentBtn
ButtonSeparator
MacroRecBtn
MacroPlayBtn
MacroLibBtn
ButtonSeparator
BeautifyBtn
SaveBtn
ExecuteBtn
BreakBtn
ButtonSeparator
CommitBtn
RollbackBtn
ButtonSeparator
ExplainPlanBtn
QueryBuilderBtn
FindDBObjBtn
CompileInvObjBtn
ButtonSeparator
HTMLHelpBtn
[KeyConfiguration]
File / Save=16467
File / Exit=32883
Edit / Undo=16474
Edit / Redo=24666
Edit / Cut=16472
Edit / Copy=16451
Edit / Paste=16470
Edit / Select All=16449
Edit / Recall Statement=16453
Edit / Selection / Indent=16457
Edit / Selection / Uppercase=16469
Edit / Selection / Lowercase=16460
Edit / Find=16454
Edit / Replace=16464
Edit / Find Matches=16461
Edit / Go to Line=16455
Edit / Next Tab Page=16456
Edit / Previous Tab Page=24648
Session / Execute=119
Session / Break=8219
Session / Commit=121
Session / Rollback=8313
Debug / Toggle Breakpoint=16450
Debug / Start=120
Debug / Run=16466
Debug / Step Into=16462
Debug / Step Over=16463
Debug / Step Out=16468
Tools / Macro / Record=122
Tools / Macro / Playback=123
Tools / Explain Plan=116
Tools / Code Assistant=117
Help / HTML Manuals=112
Editor: Start of Document=16417
Editor: End of Document=16418
Editor: Start of Line=36
Editor: End of Line=35
Editor: Delete Line=16473
Editor: Delete Prev Word=16392
Editor: Word Left=16421
Editor: Word Right=16423
Editor: Goto Bookmark=16465
Editor: Set Bookmark=16459
Editor: Navigate Back=32805
Editor: Navigate Forward=32807
SQL Window: Previous SQL=16422
SQL Window: Next SQL=16424
SQL Window: Fetch next page=32802
SQL Window: Fetch last page=32803
Have you any ideas as to what might be causing the problem?
Best regards
Billy
PL/SQL Developer
Version 7.1.5.1398
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
Plug-Ins
Aliases
(ADDRESS
(CONNECT_DATA
(DESCRIPTION
(PROTOCOL
(SID
admin.world
admin_bck.world
admin_dr.world
pccsp.world
tstmaina.world
Homes
DLLs
TNS File
Using
Home: DEFAULT_HOME1
OCI: Version 8.1
Character Sets
CharSetID: 871
NCharSetID: 2000
[General]
Enabled=True
Order=0
Rules=
[Preferences]
OpenTransaction=2
OCIFile=
UseDBAViews=True
SelectedStatNames=
SpcExt=pks
BdyExt=pkb
BackupFiles=0
BackupAbsPath=
AutoSelectSQL=True
QueryResultStyle=2
SavePFInfo=True
PFInfoLocation=0
PFInfoRelPath=
PFInfoAbsPath=
MultiRowTabs=True
KeywordsBold=True
KeywordsColor=255
CommentEnabled=True
CommentBold=False
CommentItalic=True
StringsEnabled=True
StringsBold=True
StringsItalic=False
NumbersEnabled=True
NumbersBold=True
NumbersItalic=False
NumbersColor=39423
SymbolsEnabled=True
SymbolsBold=True
SymbolsItalic=False
CustomEnabled=True
CustomBold=True
CustomItalic=False
CustomColor=8388736
CustomBkg=-16777211
KeywordsCase=1
DisplayLineNrs=True
LineNrsInterval=0
LineNrsFontSize=9
HighLightLine=True
DateFormatID=0
[ToolButtons]
FileLogonBtn
ButtonSeparator
UndoButton
RedoButton
ButtonSeparator
IndentBtn
UnIndentBtn
CommentBtn
UnCommentBtn
ButtonSeparator
MacroRecBtn
MacroPlayBtn
MacroLibBtn
ButtonSeparator
BeautifyBtn
SaveBtn
ExecuteBtn
BreakBtn
ButtonSeparator
CommitBtn
RollbackBtn
ButtonSeparator
ExplainPlanBtn
QueryBuilderBtn
FindDBObjBtn
CompileInvObjBtn
ButtonSeparator
HTMLHelpBtn
[KeyConfiguration]
File / Save=16467
File / Exit=32883
Edit / Undo=16474
Edit / Redo=24666
Edit / Cut=16472
Edit / Copy=16451
Edit / Paste=16470
Edit / Find=16454
Debug / Start=120
Debug / Run=16466
Best regards
Billy
