Key Configuration changes do not work
Dan reidy
My key configuration simply does not work. The assignments I make and save do not work. The simplest example is that I eliminate F1 (HTML manuals), by highlighting the line and hitting and save it. I go back to preferences and see that it is correctly removed.
When I hit F1, I still get the HTML manual. Assignments on new keys do not work either. I have closed and re-openned PLSQLdev, which made no difference.
PL/SQL Developer
Version 7.0.1.1066 (MBCS)
02.25990 - Unlimited user license
Physical memory : 1,048,048 kB (605,936 available)
Paging file : 3,045,588 kB (2,663,072 available)
Virtual memory : 2,097,024 kB (1,989,368 available)
Parameters
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Plug-Ins
Aliases
Homes
DLLs
C:\Local\Oracle\Clients\9203.2\bin\oci.dll
TNS File
C:\Local\Oracle\Clients\9203.2\Network\Admin\tnsnames.ora
Using
Home:
DLL: C:\Local\Oracle\Clients\9203.2\bin\oci.dll
OCI: version 9.2
Oracle Database 10g Enterprise Edition Release 10.2.0.2.0
Character size: 4 byte(s)
